1 members (baldeagle), 36 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#986197 11/14/2013 4:31 AM
Hello all,
I'm in the final stages of preparing to restart the 235 in my '61 Apache after headwork and some upgrades. I've put Fenton headers and the dual Fenton intake with a pair of Tom Langdon's Carter/Webers. I'm using the stock linkage from the pedal to the rocker link that's attached to the block, and the linkage supplied by Tom with the carbs. The trouble is joining the two. I've fabricated a connecting bar, using a bend in the rod with a clip on the rocker link side, and a the ball joint type connector on the carb linkage side. I'm having a heck of a time getting it to operate smoothly, and I was hoping some 'Bolters out there have the same setup. If you could offer advice on what you did and perhaps a picture or two, I'd be grateful. Thanks in advance.
Greenman Wood
"Beatrice" - '61 Apache 10 longbed stepside
"The duty of a patriot is to protect his country from its government." - Thomas Paine
Hello Greenman.
What you are doing is my next project. I have a 235 as well. I would like to know how your performance improves. Would you let all of us know? Thanks!
Thom Masterson
Sure, Bats! As soon as she's going, I'll let you know.
I have dual quads and use a linkage setup by wiend or holley. I think the companies merged. It might work for you application. I have no clue how to post pictures, sorry.
could you try a ball joint (hyme joint) on both ends?
they usually work pretty smooth.
