| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98615 12/27/2006 12:06 AM | Joined: Jan 2006 Posts: 31 Apprentice | | Apprentice Joined: Jan 2006 Posts: 31 | I have a 1957 chevy truck doing a frame off restoration. Using stock gauges, putting in AC, Power steering, power brakes, newer reproduction radio. Need advice on what brand wiring harness to buy. Would like to keep it around $200 or less if possible. Oh yea, have an Ididit steering column with shift & tilt. Am a first-timer and need something easy to install. Thank you! David PS - I see the EZWiring systems in the magazines - 21 circuit for $185. Any good? | | |
#98616 12/27/2006 12:07 AM | Joined: Jan 2006 Posts: 31 Apprentice | | Apprentice Joined: Jan 2006 Posts: 31 | PS. PS - will probably be adding power door locks and windows as well. Thanks in advance! | | |
#98617 12/27/2006 12:17 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | EZ is good, and cheaper direct - and Painless is good too at about the same price Bill | | |
#98618 12/27/2006 12:50 AM | Joined: Oct 2006 Posts: 22 Junior Member | | Junior Member Joined: Oct 2006 Posts: 22 | i've used ron francis, painless and ez in wiring street rods that i built. the main difference is the price. i am installing the ez mini in my 1958 3100....real ez | | |
#98619 12/27/2006 6:01 PM | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used a Painless kit in my build - went great and I am totally new to auto electrics ! Picked mine up on E Bay for a good price. Has all the extra circuits for windows / locks / stereo / AC etc. | | |
#98620 12/29/2006 2:21 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This was very thoroughly discussed here recently. If you run a search you'll find there are bunches of opinions on this. | | |
