| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | So I'm about to start prepping my 49 can and clip for paint. What safety and health concerns are there with the old paints? Were any lead based or did they only use that in old house paint?
I will use the obvious niosh dust mask and gloves, and old clothes. I have two little ones and don't want to contaminate them. I have a washing machine in the shop for work clothes, so I can leave coveralls in the shop and not wash along with their clothes. Just want to be safe around them. Thoughts | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | dust is the only problem, you're safe
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That dust taint killed Bill and he's 96 years old.
Just as long as you don't eat it, it won't do any brain damage.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | .............Unless you start sanding/ grinding on the old body seams. Theres lead in them thar parts. Just use a little extra caution in those areas and you (and yours) will be fine.
