Brrrr
1 members (baldeagle), 134 guests, and 0 robots.
Topics128,274
Posts1,058,432
Members48,489
#985320 11/11/2013 6:33 AM
Just curious what it takes to drop an apache 4" up front and 6" in the rear? It's torsion bar. Do I just crank away until it sits how I like and cut bump stops? I know I can get springs for the rear. Just curious. Thanks guys.
I lowered a 1968 Valiant by adjusting the torsion bars.Re-alignment was needed after
you may want to call this guy. dropped axels by Sid
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Thanks guys
Nostalgia Sids is a Oklahoma based company with a great reputation for service.
While Sids does excellent work, it's not the solution here, as the truck being asked about is a torsion bar IFS.
Lowering the front, I would advise against simply turning the bars down. While it will work, it will also alter the spring rate, making it too soft to support the weight of the truck. A better solution to lower it without drop spindles would be to re-clock the bars in relation to the control arms. That way, you get the ride height that you want without sacrificing spring ride, handling, and ride quality.
Bill Burmeister
Are there any crossmember swaps that will work? I've heard of mid 70's working with just holes needed to be drilled. Any truth to this? I'm looking to swap a crossmember and use the disc brakes, booster and power steering.
Yes, 73-87 front suspension bolts right up. I've never done it, but a guy I know has done this to his truck and put a lot of reliable miles on it.
My 46 GMC on Photobucket
Thanks guys for all the input
