2 members (baldeagle, Shardean),
31
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Just curious what it takes to drop an apache 4" up front and 6" in the rear? It's torsion bar. Do I just crank away until it sits how I like and cut bump stops? I know I can get springs for the rear. Just curious. Thanks guys.
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I lowered a 1968 Valiant by adjusting the torsion bars.Re-alignment was needed after | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | you may want to call this guy. dropped axels by Sid
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 |
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Nostalgia Sids is a Oklahoma based company with a great reputation for service.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | While Sids does excellent work, it's not the solution here, as the truck being asked about is a torsion bar IFS. Lowering the front, I would advise against simply turning the bars down. While it will work, it will also alter the spring rate, making it too soft to support the weight of the truck. A better solution to lower it without drop spindles would be to re-clock the bars in relation to the control arms. That way, you get the ride height that you want without sacrificing spring ride, handling, and ride quality.
Bill Burmeister | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Are there any crossmember swaps that will work? I've heard of mid 70's working with just holes needed to be drilled. Any truth to this? I'm looking to swap a crossmember and use the disc brakes, booster and power steering.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yes, 73-87 front suspension bolts right up. I've never done it, but a guy I know has done this to his truck and put a lot of reliable miles on it. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Thanks guys for all the input
