6 members (GRNHydra, Oswald, Southerntruck, 1955 1 Series, Nick in Manitou, Wayne67vert), 122 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
#985853 11/13/2013 1:07 AM
I
I Offline
I have gone through quite a few posts on here but can not find anything about the C60's that have the 5 lug front wheels. I have already planned to purchase new rear 10 lug rims when they become available at a cheaper price in the spring from wheels now, but the 5 lug fronts have me scratching my head. I can have them custom made for about $335 a piece but I would like to find a cheaper alternative if its possible but I'm thinking I will end up going the custom route. Does any one have any specs or info they could share with me on these 5 lug wheels?
1965 Chevrolet C-60 292 Flatbed
2008 GMC Sierra SLE Z71 Crew Cab
1992 Chevrolet C1500 Cheyenne 5 Speed
2001 Harley Davidson FLHT Electra Glide Standard
Are you sure they are not 10 lug wheels that only use 5 lugs? Ther is probably a cover over the center of the wheel to cover the lugs not used.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
3B Offline
Hy IHBoilermaker, after checking my parts book, it sounds like you have the 5/10 stud Kelsey hub piloted wheels on your truck. Each wheel has ten stud holes on an 8.75" bolt circle, the wheels when used on the front axle only use five studs/nuts there were cover plates for the front wheels that would hide the fact that you were only using five of the ten holes in the wheel. I have tried to verify about the cover plate on your year of truck, but so far I have not come up with a part number for the cover plate, hope that helps.
3B #986101 11/13/2013 11:15 PM
I
I Offline
These are pics of my front wheels as it sits now. I also included one of the rear setup. So essentially I could just add five more studs to the drum and make these 10 lug?
url=http://www.flickr.com/photos/70242525@N05/10844246255/
[url=http://www.flickr.com/photos/70242525@N05/10844390424/in/photostream
[url=http://www.flickr.com/photos/70242525@N05/10844305386/in/photostream/
3B Offline
Hy IHBoilermaker,yes you could do that if you really don't have anything else to do, more studs are not required for front wheel retention.
3B #986133 11/14/2013 1:49 AM
I
I Offline
Ahhhh..I see what your saying.....The new ten lug wheels will just bolt right on without any additional lugs added...I don't know why I was looking at it that way...duh
we all need a little bump in the right direction sometimes....that what this forum is all about.
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
