| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | 1957 3100 Short Step.
A friend here used McCormick's "Cote All" (Alkyd Poly) to paint his truck and I want to do the same.
Unfortunately, other than the cab, there's not enough of my 767 Royal Blue left on any removable part that I could take to my local store. The store seems to keep banker's hours for some reason, so I can't even drive the truck there to show them.
Does anyone know of a paint code I could give the McCormick guy that he would understand and could use to formulate the correct color? I don't need it to be a perfect match.
Thanks in advance,
Jim | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ditzler and Dupont numbers here - also a Corvette pic sample and a bunch of other numbers hereBill | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Thanks Bill,
Something told me you'd come through on this...
So, the McCormick guy should be able to understand Ditzler and Dupont then?
Best,
Jim | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no telling if those numbers will translate, but it's a place to start, the 2nd link with the Ditzler/PPG #12174 might be the most "modern"
Bill | | |
