0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What is the question? You took it apart to remove it...from the dash? "Should have looked up how to remove this light switch"? Do you mean should have looked up how to disassemble or assemble? What do you need from us? How to wire it back up? http://www.classicchevy.com/assets/illustrations/classicchevy/25-01.jpg
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | Don't think Los59 is posing a question or looking for an answer. I think he is just saying if I looked for the answer before destroying the switch I would not have destroyed the switch. I think this not cause I am smart, it is because I have messed up so much. Los59, there is a boatload of info here, it's overwhelming. Seems almost all the problems you will run into have been asked and answered. What I do is if I start something and have a problem, I clean my hands, log on, search and read and usually the answer is here with pictures and everything.
Welcome to the journey! | | | | | Joined: Oct 2013 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 32 | Yeah, sorry no actual question. Was just a bit of humor cause I'm sure I'm not the only one who has done this before. Also kind of an update on my project.
Which brings up a question, instead of posting little updates all over the site, is there a preferred place for project updates/progress?
"Start living your dream now no matter what the sacrifice, and everything else will fall into place."
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | try a post in the DITY forum, or climb on the "what did you ..." thread in general truck talk, humor belongs in the greasy spoon Bill | | | | | Joined: Oct 2013 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 32 | Ok good deal, thanks Bill.
