2 members (46 Texaco, sron48),
146
0
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | I have gone through quite a few posts on here but can not find anything about the C60's that have the 5 lug front wheels. I have already planned to purchase new rear 10 lug rims when they become available at a cheaper price in the spring from wheels now, but the 5 lug fronts have me scratching my head. I can have them custom made for about $335 a piece but I would like to find a cheaper alternative if its possible but I'm thinking I will end up going the custom route. Does any one have any specs or info they could share with me on these 5 lug wheels?
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Are you sure they are not 10 lug wheels that only use 5 lugs? Ther is probably a cover over the center of the wheel to cover the lugs not used.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IHBoilermaker, after checking my parts book, it sounds like you have the 5/10 stud Kelsey hub piloted wheels on your truck. Each wheel has ten stud holes on an 8.75" bolt circle, the wheels when used on the front axle only use five studs/nuts there were cover plates for the front wheels that would hide the fact that you were only using five of the ten holes in the wheel. I have tried to verify about the cover plate on your year of truck, but so far I have not come up with a part number for the cover plate, hope that helps. | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | These are pics of my front wheels as it sits now. I also included one of the rear setup. So essentially I could just add five more studs to the drum and make these 10 lug?
url=http://www.flickr.com/photos/70242525@N05/10844246255/
[url=http://www.flickr.com/photos/70242525@N05/10844390424/in/photostream
[url=http://www.flickr.com/photos/70242525@N05/10844305386/in/photostream/
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IHBoilermaker,yes you could do that if you really don't have anything else to do, more studs are not required for front wheel retention. | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | Ahhhh..I see what your saying.....The new ten lug wheels will just bolt right on without any additional lugs added...I don't know why I was looking at it that way...duh
| | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | we all need a little bump in the right direction sometimes....that what this forum is all about. | | |
