3 members (PullG, Tronman, 1 invisible),
133
Mod | | | Forums66 Topics128,288 Posts1,058,578 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | OK, been working on my 235 (58-61) and i am ready to put it in my 49. Was wondering if someone can give me some advice on attaching my chains to the engine. I will be using a chain hoist and rolling the truck under the engine to set it in, but not really sure what bolts I need to use to lift engine. Any advice will be appreciated. Thanks. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Here is what I did. I used 3'6" of 3/8" and I unbolted the last bolt going into the head (closest to the firewall on the carb side) and I used the bolt hole on the front of the motor besides the thermostat housing. Just make sure you get the threads all the way in and use washers. My cherry picker was a one ton lift from HF that worked for me. Just go slow.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I just use those nylon HF ratchet straps. The motor weight less than 700lbs total and each strap only sees about 350.. well within their rating.
I use a gantry crane to lift it off the dolly and if it doesn't lift level I set it down and readjust the length of the straps.
I've found the gantry MUCH more useful than an engine hoist.. and it only costs slightly more than a 2 ton hoist.
