| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | I need a shift arm that goes on the side of my 1953 sm318 transmission, the one that your linkage hooks up to at the tranny. Can some one tell me how far up they used those type of arms. Thanks. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | They used that configuration through 55 2nd series w/235 engines. I have a collection of the shift arms. I could send you one for the cost of postage. Fred
| | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | I found one today. had to modify it and if it doesn't work out I will get ahold of u. Thanks very much.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Just saw a set of these on ebay, don't have number, you'll have to search. Good luck | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Problem solved. My brother had one. I did a little work on it and now i think all is well again. Seems like i take one step forward and 2 back. Should be able to take it down the street and back for a test in a couple days. Been a long 2 yrs. . | | |
