6 members (Wickedbass, jkreiner, mvigo, Charles in CA, Rusted Nut, 1 invisible), 75 guests, and 3 robots.
Topics128,074
Posts1,055,913
Members48,429
#985393 11/11/2013 4:42 PM
Can anyone tell me what the cranking pressure should be for a 1950 GMC 228 motor please. I've just done a compression test and they all came out around 100psi on a cold motor.
cheers
My 1958 motors manual says 130@ "cranking speed" for 248 to 270 for most years it lists...
Sound like your in the game to me...
Give me ambiguity
or give me something else
That's low. I'd of thought 150-170psi
You may want to add some oil to the cylinders and retest and see if the numbers change. The good news is that your cylinders are all real close to each other so I would not be to worried about the actual number.
Compression specs, I believe, usually assume a fully warmed motor, all spark plugs removed, and throttle held wide open.
Yeah, I was pleased to see the pressures were very close. So I don't think I have much to worry about. It was more to see how the motor was fairing. I've yet to do a test when hot, or a leak down.
In the pipeline just haven't got round to it yet.
Cheers
Doh!!!
my mate came round last night for the compression tester. I'd not been wearing my glasses when I did the test, so didn't see the gauge too well.
Sooo it turns out it was reading 10bar not 100psi. lol
So more like 145-150psi per cylinder.... happy days.
Still need to find out why is burning sooooo much oil though??
Check the exhaust valve guide clearance- - - -lots of oil can go down the exhaust pipe without ever being noticed as fouled spark plugs or smoke. If it doesn't get into the combustion chamber and get burned, the characteristic blue smoke doesn't always become apparent.
I think you might be onto something there, as on startup it always coughs out a load of soot. I might take the head off and get the guides replaced
