2 members (greenie-reddy, carbking), 47 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#985249 11/11/2013 1:56 AM
Having a little trouble determining correct pushrod length for a 1955 261 Jobmaster Engine. This engine is total NOS short block and I assume that it was to use solid lifters for HD truck use. This is not a Poncho block used in the great white north.
What I'm trying to avoid is spending $$ for a set of pushrods and then having them turn to pretzels and having the supplier say oops! sorry, wrong size.
Thanks...Rustnut
There is not a tool made that if you don't try hard enough you can't break!
1952 3100 261 T5 3.08 Gov Locker
Rustnut #985491 11/11/2013 10:47 PM
Egge shows 2 pushrods for the 261. 55 early and 55 late.
48014 is the early 55 and 235
48013 is the later 55 and 235
Call them to make sure. 1-800-866-3443
Steve H
