9 members (Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L., 55shaker, Wally / Montana, Uncles51),
83
Mod | | | Forums66 Topics128,075 Posts1,056,003 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 10 New Guy | | New Guy Joined: Nov 2013 Posts: 10 | In trying to find a original ashtray for this pickup I noticed that in the dash there are no provisions (except the cutout)to hold the ashtray in place. I assume there should be some guides on either side for it to slide on. It does not appear that anything has been removed or cut from the dash. Any ideas? Thanks | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Should be a squarish guide for ash tray to slide into. Think it's welded to the dash, I'll have to look and see how mine is. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have an ash tray I'll give you if you donate 25.00 dollars to this website or a charity. Send me your address at [email protected]. There is just a guide above the opening. I'll post a couple of pictures on my photobucket. | | | | | Joined: Nov 2013 Posts: 10 New Guy | | New Guy Joined: Nov 2013 Posts: 10 | Thanks for the info gents. I found a pretty good photo of the back of the panel. Someone must have removed these brackets, they did a real nice job I might add. I don't mind fabricating something even if it only holds the ashtray in permanently. Thanks again! | | |
