2 members (BC59, Bill Hanlon), 152 guests, and 2 robots.
Topics128,088
Posts1,056,109
Members48,434
In trying to find a original ashtray for this pickup I noticed that in the dash there are no provisions (except the cutout)to hold the ashtray in place. I assume there should be some guides on either side for it to slide on. It does not appear that anything has been removed or cut from the dash. Any ideas?
Should be a squarish guide for ash tray to slide into. Think it's welded to the dash, I'll have to look and see how mine is.
1946 1/2-Ton Chevy
I have an ash tray I'll give you if you donate 25.00 dollars to this website or a charity. Send me your address at [email protected]. There is just a guide above the opening. I'll post a couple of pictures on my photobucket.
Thanks for the info gents. I found a pretty good photo of the back of the panel. Someone must have removed these brackets, they did a real nice job I might add. I don't mind fabricating something even if it only holds the ashtray in permanently. Thanks again!
Moderated by  ndkid275, Phak1
