2 members (baldeagle, Oswald),
42
10
Mod | | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98484 12/17/2006 2:00 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | I am missing a spring on the return when you step on the gas pedal...where does the spring connect to down by the motor...Does anybody have a pics to show me... | | |
#98485 12/17/2006 3:36 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | why are you posting this again Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#98486 12/17/2006 3:44 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | You didn't answer my question..I already have the throttle cable and choke cable attached....i have no return when I push on the gas pedal...I believe I must be missing a spring that attaches from the arm (when I say arm I mean the 1/4 shaft that comes from the gas pedal...half way on my arm I have a clip with a hole..it appears to be where a spring was attached and other end I have no idea with...that is my question where does the other end attach to...the side of the block? | | |
#98487 12/17/2006 6:04 AM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | holcomb you can reply to your original message. | | |
#98488 12/17/2006 6:08 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | thankyou for your reply that makes great sense... | | |
#98489 12/17/2006 6:32 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Holcomb,,disregard the "clowns" that throw in stupid answers just to be "jokers". theres a spring that goes from the bell crank on the throttle linkage to a point on the block to put tension on your throttle linkage for the return. i dont have a picture but if you look at where your gas peal rod goes to the pivot point,the spring goes there back to a stud on the block,,or down to the lil clip sticking up from the side of the oil pan. hope this helps,Marty | | |
#98490 12/17/2006 7:18 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | disregard the "clowns" that throw in stupid answers just to be "jokers". Some "clown" posted the question 3 times in the electrical forum. What should he expect? | | |
#98491 12/17/2006 7:27 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Holcomb:
This is not a chatroom, so don't get impatient and expect immediate answers and only post the question once in the correct forum for best results. | | |
#98492 12/17/2006 8:27 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | hes a new guy,,,lighten up on him...... | | |
#98493 12/17/2006 1:27 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Maybe Holcomb writes SPAM in his off hours? Just pokin fun at ya guy, hope ya appreciate this, I been under a old greasy truck since 04:30 to get ya these pics! See, we're not all that bad! Next time though, ya should post this in a more appropriate forum to avoid a Red Assin’, it certainly taint an electrical question. Sounds like your missing the little tab that Marty is describing. Here’s a picture, saves a thousand words ya know, oh, by the way it’s of a stock 1950, 3604! http://rides.webshots.com/photo/2271210920098611668XzglNz Denny Graham Sandwich, IL
Denny G Sandwich, IL
#98494 12/17/2006 4:52 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | hey delux 54, if you were throwing that dart at me , you made a hit,,,,,,,,,I was just asking as I had just spent some time trying to get him an answer, like using the search, going to cletis old pix and such............
why didn't you take the time to try and find a pix for him....... what was stupid about the answer..and you have been here long enough not to give an response as you did..
appreciate your kindness.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#98495 12/17/2006 5:06 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
Good answer. Good picture. The replies and descriptions were going nowhere.
I think Holcomb now knows to post once in one forum. He probably now understands that most people who use this site check out all the forums and an answer usually shows up in a reasonable amount of time.
Tim | | |
#98496 12/17/2006 5:12 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Yes Denny.........great job on your response and Tim you are so correct... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#98497 12/17/2006 8:52 PM | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | Originally posted by Holcomb: thankyou for your reply that makes great sense... Just for the record... I wasn't trying to be sarcastic. I had replied to one of the other posts from holcumb on the same subject. Heck I'm just now geeting the hang of the bolt, certainly don't want to discourage anyone. | | |
#98498 12/18/2006 4:07 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeper, hope we dint scare him away. I worked for 27 years at my last job, it was one that if you didn’t have a thick skin, ya just didn’t last all that long. We would gather round the coffee pot first thing in the morning and someone would always get it. If you were lucky you missed your turn in the barrel, but if ya were to slow they’d get ya and ya just had to grin and bare it. COME ON BACK HOLCOMB! Heck, I been a trying to get answers from these Bozos for three months now and they keep ignoring me too! Since it was my weekend for a bath there taint no excuse for them to ignore me now. Denny Graham Sandwich, IL
#98499 12/18/2006 4:16 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeper, hope we dint scare him away. I worked for 27 years at my last job, it was one that if you didn’t have a thick skin, ya just didn’t last all that long. We would gather round the coffee pot first thing in the morning and someone would always get it. If you were lucky you missed your turn in the barrel, but if ya were to slow they’d get ya and ya just had to grin and bare it. COME ON BACK HOLCOMB! Heck, I been a trying to get answers from these Bozos for three months now and they keep ignoring me too! Since it was my weekend for a bath there taint no excuse for them to ignore me now. Yeper, hope we dint scare him away. I worked for 27 years at my last job, it was one that if you didn’t have a thick skin, ya just didn’t last all that long. We would gather round the coffee pot first thing in the morning and someone would always get it. If you were lucky you missed your turn in the barrel, but if ya were to slow they’d get ya and ya just had to grin and bare it.
As a side note, (seems like we're havin a hard time staying on task here) the throttle spring that I got from the vendor seemed a whole bunch to heavy for me. When the vertical link started to bow in the middle I figured I better find one with a little less tension. All this stuff wears out fast enough, it doesn't need any help from an over tensioned spring. Luckily I keep about every spring that I run across, plus some and I had the one in the picture, that gave me that just right feel.
#98500 12/18/2006 5:43 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | you guys didn't scare me away...I have students who bring guns and knifes to school...involved in huge gangs...big riots...cops everyday on campus which then they try and burn the building down I work in....so thick skin huh...you haven't seen nothing dude. So thanks for the pictures everybody...they were very helpful | | |
#98501 12/18/2006 2:56 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Glad to see ya back Mr. Holcomb. Don't envy you having to teach those second graders, thay can be a real challenge. And glad to help ya out when ever we can. Although I eat, slept and drank cars when I was a teenybopper back in the late 50’ I’m I have been engaged in other endeavors for the last forty odd years. I’m a newbe here also and have found this site and these guys to be an invaluable resource and would never have been even close to where I am in my restoration with out them. Now don’t ya go and grade this paper, ya hear!! Denny Graham Sandwich, IL
