9 members (TUTS 59, moparguy, 50Chevy3100, FAST55, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf), 93 guests, and 4 robots.
Topics128,065
Posts1,055,870
Members48,428
#984808 11/09/2013 2:46 PM
Hell guys, I just picked up a nice 41 pickup with a 216. My question is about the putting the temp probe in the head. I've talked with a fellow who sent me some pics of his probe in the head but mine will fall right though the hole. His engine is a 41 and I looked up mine and it's dated 1940. Did they use a adapter when they put the probe in a 1940 head? I don't believe I can just throw a pipe reducer in there because I think the sensor has machine threads and not pipe threads on it.
Thanks for the help.
tom sampson #984812 11/09/2013 3:08 PM
Tom I am not sure about the years they fit but several of the vendors like Jim Carter and Classic Parts sell this adaptor.
tom sampson #984816 11/09/2013 3:20 PM
The sender reducer/adapter that Brad refers to works in later 235/261 heads that were made for an electrical sender that had a wider diameter than the mechanical/tube sender (sometime after 55-1st).
Presumably, you are referring to a 1940 216 head and 1941 216/235 head? Maybe that hole changed when the 235 was introduced?
That reducer might work in an earlier 216/235? It was available at NAPA - I'll look for the part number.
tom sampson #984836 11/09/2013 5:06 PM
Up to 1940 there was a factory reducer, similar to what Tim linked to, only it was slightly taller.
What year is the engine? You do not want to use a 1940 head on a 1941 or later engine. 1940 was the last year to use dome pistons. If you use a 1940 head on a 1941 or later engine you will have very low compression.
My Blog
tom sampson #984917 11/10/2013 12:08 AM
I checked my serial number and the engine is a 1940. Thanks for the help everyone!
