4 members (MRMEROTH11, Hotrod Lincoln, 52Carl, klhansen), 70 guests, and 2 robots.
Topics128,052
Posts1,055,773
#3111 11/16/2001 12:26 AM
Hi all,
Has anyone out there converted a late 5T's rear brake set up to a later SELF ADJUSTING rear brake set up?
I've got discs up front, but I would love to avoid having to adjust the rear shoes if it's possible. I don't see any need to go to disc in the back.
-alfie
-alfie
#3112 11/17/2001 5:55 AM
What's wrong with adjusting? should only need to do it every 2 years or so, maybe less if you don't drive it much. Anyway, seems if you had a 51 or up with bendix brakes you could get later model backing plates and hardware with adjusters to change yours out. I'm not sure what year they started self adjusters, but I know the shoes cover almost 2 decades of truck years. Maybe you won't even need the backing plates changed, maybe you just need the other hardware to put on shoes with small cable and arms and ////// whatever it used.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
What is the range of fit for my 41' half ton. It had a leaking rear cylinder and shoes on that side are pretty saturated with brake fluid. Can I just take them to Napa and match them up?
Crusing in the Passing Lane
If you ae lucky, great, it's always quicker and better to just get new slaves, shoes, drums, than fooling around with wornout and soaked parts, if available.
If not, rear axles with modern brakes and lower numerically axle ratios are cheap and plentiful.
1941 would have been the huck brakes. Not sure if there were any changes in them between your truck and 1950 when they chnged over to Bendix or not. I should think replacement or rebuild kits are available for the wheel cylinders. I believe you are only allowed .004 thousands on honing a wheel cylinder. So if the bores are pitted then you'll need to replace them or have them sleeved.
Anyone had their brake wheel cylinders sleeved with stainless or brass? I believe White Post did them in brass, but did see others offering slainless sleeves.
I have converted Bendix brakes to self adjust many times.
I order kits for a 65 PU, although they were used for many years.
Because the adjuster wheel will be on the rear side, on both sides, it is necessary to drill and slot two of the backing plates if you want access to all adjusters.
My Blog
Originally Posted by Whitelightning
Anyone had their brake wheel cylinders sleeved with stainless or brass? John
I have Hagen's sleeve all of my cylinders with stainless.
My Blog
I'd recommend removable plugs if you drill the backing plates. Especially on a daily driver. Nasty crud on the roads. I have self adjusting drums but I still like to check once in a while. Safety third
