| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | I keep the shop at 57 degrees with radiant floor heat. Nice and toasty today.
John G 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | My experiences are tainted by having printing presses involved. You don't print without 72 degrees min. The ink imulsification is really a problem. Different papers behave differently, The pH of the water solution, etc. so the shop is always a constant 72. Turns out that works really well for painting, preserving rubber, pretty much anything having to do with seven vehicles in the shop, etc. I feel good because its not about my comfort. LOL! | | | | | Joined: Sep 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 51 | I insulated the walls, and then sheetrock. I put some of that 1/2 inch foil faces styrofoam on the ceiling joists. I drop a plastic sheet in front of the garage doors. I run a propane element on the tank and I can get my 2 car garage from 30 degrees up to almost 60 in about an hour. Work for me!
Love the classics! 1954 3100 1965 Mustang vert
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | An outdoor wood furnace would be nice. The fellow that drilled my water well said he had one. Said all you have to do is run lines to whatever building you want to heat.
John | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | My 2 cents. Here in this part of Canada more and more people are starting to use pellet stoves. $5 for a bag of pellets at Walmart will give you 2 days daytime heat @ 70 to 75 deg. very nice when the temperatures are below zero outside. Burns super efficiently and clean, no chimney required just a small vent. Unlike firewood there is almost no labour to it. No wood to split, no bugs, no stacking to dry. I would rather spend my time working on my Truck. I absolutely love this stove. About 20 years ago Scandinavian people were the inventers and since then heat most of their homes this way. Sure is a cool invention and worth checking it out. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I heat my shop with propane Infrared Heaters (the long black tube with a metal reflector). The temperature in the shop gets down to about 45 degrees on cold nights and the heaters can bring it up to mid 60's in about 30 minutes or less. Once it's up to temperature it almost never comes on. The neat thing about infrared is I can heat the shop with the door open, not that I do that, but it is nice when you want to move a truck out you don't loose all of your heat! My house has radiant in the basement floor and it's great! I have the loop water temperature set at about 100 degrees which feels great on the feet. When the kids were little they would sit and play on the floor all day long. The kids are all grown up and we still heat the floor during the coldest months in the winter even though we don't use the basement, it just makes the whole house feel good... If I was to build again I would concider solar powered radiant floor heat as it's almost free heat, you only need to pay for the circulating pump electric (after the installation cost). Mike B  | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I have to work very fast so my shop stays warm from my body heat. The colder it get the faster I need to move. That's what I do up here in the north country..
| | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | My shop is 40x48 and has 7 zones of hydronic heating.(2,100ft of 5/8 tubing) The concrete slab is about 6" thick and is a wonderful heat sink. Never had a concern of a hot floor as the glycol is kept at 90F. The outdoor temp. in southern Alberta last week was -20C. and the air temp. about 1" above the floor is about 65F. This method of heating is very even and no air with dust is blowing around. I have a 20 foot long radiant tube heater above the work bench for quick warming after the overhead door was opened.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | |
