5 members (Johnny N, tesa, Chris's 46 / 515, Gray_Ghost, Youngin' Tut 59), 76 guests, and 2 robots.
Topics128,076
Posts1,055,924
Members48,430
#984601 11/08/2013 8:09 PM
I've got a 57 Chevy 2-Ton that I am trying to remove the pressure plate and clutch disc. Do I have to lift the engine to accomplish this? Or is there a trick? Right now the transmission support is getting in the way and I don't have a way of hoisting the engine right now. If someone knows a trick, let me know.
Glory Bound...
Have you tried pulling the disc out between the flywheel and pressure plate first? That should work
My Blog
Raul T. #984634 11/08/2013 11:25 PM
I did not try that. Just because the disc has that middle portion with the spline teeth that is pretty wide. But I'm gonna give it a shot. Thanks.
Glory Bound...
Raul T. #984655 11/09/2013 12:06 AM
You may need to pull the fork and pivot ball to gain enough room.
My Blog
The fork is out, but I'll take a look at the pivot ball.
Glory Bound...
Raul T. #984890 11/09/2013 10:13 PM
Isn't the pressure plate held by 3 locating dowels?
FIRST: take a small chisel and mark an area of mating surfaces from the pressure plate and flywheel. So when you put it back together, the old pieces will line up the way it was.
Take a look at the pressure plate 'fingers'. DO they have a groove worn near the inner ends? (that's the wear pattern from the throw out bearing.. You DID check that too didn't ya?)
If it's worn badly replace, But if not you can keep it as long as it's not grooved where the clamping plate gripps the disc.
Also, check the flywheel itself. If it's grooved, it's better to pull it and have it surfaced. If the $$ isn't there at that time, one can put a new disc inbetween but it may CHATTER badly when letting off the clutch peddle.
Some mfgrs will have the dowles in a pattern that lets it go on ONLY ONE WAY.. Kind of hard when you're under there trying to hold everything together and (with your 3rd hand) rotating to find the right fit. Then you may run into a clutch mfgr that seems to punch the dowel holes just-ever-so smaller, and the dowels won't fit in the holes.. Then you may have to persuede it a little..
Get yourself a heavy flat screw driver or prybar and pry apart
around the little separations on the circumference of the plate.
Errol
Raul T. #984927 11/10/2013 12:44 AM
Removing the pivot ball and holding the clutch disc up with a wire did the trick. Thanks guys.
Glory Bound...
