| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I've got a 57 Chevy 2-Ton that I am trying to remove the pressure plate and clutch disc. Do I have to lift the engine to accomplish this? Or is there a trick? Right now the transmission support is getting in the way and I don't have a way of hoisting the engine right now. If someone knows a trick, let me know.
Glory Bound...
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Have you tried pulling the disc out between the flywheel and pressure plate first? That should work
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I did not try that. Just because the disc has that middle portion with the spline teeth that is pretty wide. But I'm gonna give it a shot. Thanks.
Glory Bound...
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You may need to pull the fork and pivot ball to gain enough room.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | The fork is out, but I'll take a look at the pivot ball.
Glory Bound...
| | | | | Joined: May 2013 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 66 | Isn't the pressure plate held by 3 locating dowels?
FIRST: take a small chisel and mark an area of mating surfaces from the pressure plate and flywheel. So when you put it back together, the old pieces will line up the way it was. Take a look at the pressure plate 'fingers'. DO they have a groove worn near the inner ends? (that's the wear pattern from the throw out bearing.. You DID check that too didn't ya?) If it's worn badly replace, But if not you can keep it as long as it's not grooved where the clamping plate gripps the disc. Also, check the flywheel itself. If it's grooved, it's better to pull it and have it surfaced. If the $$ isn't there at that time, one can put a new disc inbetween but it may CHATTER badly when letting off the clutch peddle. Some mfgrs will have the dowles in a pattern that lets it go on ONLY ONE WAY.. Kind of hard when you're under there trying to hold everything together and (with your 3rd hand) rotating to find the right fit. Then you may run into a clutch mfgr that seems to punch the dowel holes just-ever-so smaller, and the dowels won't fit in the holes.. Then you may have to persuede it a little..
Get yourself a heavy flat screw driver or prybar and pry apart around the little separations on the circumference of the plate.
Errol
| | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Removing the pivot ball and holding the clutch disc up with a wire did the trick. Thanks guys.
Glory Bound...
