| | | Forums66 Topics128,110 Posts1,056,257 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | So I found the data tag on my 41' half ton - it's on the passenger side screewed to the side cowl/firewall. It has screew heads that look like they take a special wrench - factory installed I'm guessing. Someone painted over it as they sprayed the firewall, so only the vin number is visible as it is stamped in. Does anyone know how to remove the new paint such that I can read the identification info below it? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My data plate had been painted over as well. I tried to get the paint off but wasn't able to do so without also removing the original paint. I ended up having to buy and stamp a reproduction plate. The screw you refer to is a combination hex/clutch head screw that I don't believe is being made any longer. I've searched and not found anywhere to buy any so don't lose them. Original data plate. Reproduction plate with the screw you mention.
| | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I sure like your pics on replacing the weather stripping. A month down the road I may be asking specific questions on that. Thanks for sharing. | | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | Tiny, did you stamp your tag yourself?
John 50' chevy 3100 shortbed
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Yes. The original stamp size is an odd size which I wasn't able to duplicate exactly but it's close.
| | | | | Joined: Dec 2012 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 17 | I used sand paper, steel wool then a razor scrapper. You can read how I went about it on my blog. Follow the link in my signature.
