1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
So I found the data tag on my 41' half ton - it's on the passenger side screewed to the side cowl/firewall. It has screew heads that look like they take a special wrench - factory installed I'm guessing. Someone painted over it as they sprayed the firewall, so only the vin number is visible as it is stamped in. Does anyone know how to remove the new paint such that I can read the identification info below it?
Originally Posted by DADS50
My plate was painted over also.
You can see it in this pic Drivers door jam painter over.
I was able to take the paint off with a razor blade ID plate pic After the razor blade I cleaned it with some thinner and a rag
The original plate is silk screened I think.
Only a little bit of the edges came off.
The S/N is stamped on the plate.
Good Luck
Ex Hall Monitor
Ex Hall Monitor
My data plate had been painted over as well. I tried to get the paint off but wasn't able to do so without also removing the original paint. I ended up having to buy and stamp a reproduction plate. The screw you refer to is a combination hex/clutch head screw that I don't believe is being made any longer. I've searched and not found anywhere to buy any so don't lose them.
Original data plate.
Reproduction plate with the screw you mention.
I sure like your pics on replacing the weather stripping. A month down the road I may be asking specific questions on that. Thanks for sharing.
Tiny, did you stamp your tag yourself?
50' chevy 3100 shortbed
Ex Hall Monitor
Ex Hall Monitor
Yes. The original stamp size is an odd size which I wasn't able to duplicate exactly but it's close.
I used sand paper, steel wool then a razor scrapper. You can read how I went about it on my blog. Follow the link in my signature.
