1 members (Peggy M), 131 guests, and 2 robots.
Topics128,105
Posts1,056,538
Members48,448
I am running a 6 volt system but I added turn signals. Can anyone point me to a 6 volt two filament lamp that would be suitable for parking and turn. Right now I am playing with two lamps but I would prefer a single lamp. I will replace the stock lamp socket with a two contact one if they are available. Plenty of 12v ones available but I have not found a 6 Volt one. Thanks.
Riding in the Passing Lane
You can get universal sockets at any parts store. It doesn't matter if it is 6 or 12 volts. Use a 6 volt flasher & 6 volt bulbs. Any added wire use heavier gauge then 12 volt.
1972 Chevy c10 Cheyenne Super
You have a source for 6 volt two filament lamp?
Don't our vintage parts vendors sell them???
Here's one place that has 1154 bulbs and if you do a search for
1154 bulbs I think you'll find a ton of places that have them.
http://www.motorcyclepartsmegastore...hopping&gclid=CL-2sOP_z7oCFcs-MgodOywAVg
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I did that on my '46. I didn't want to drill holes in the fenders. The NAPA store had to special order the 1154 bulbs and I had to take the whole box of 10. It works well and looks just like original.
Thanks. I think I'll have to special order too. I struck out after work around here. But I'll use the 1154 LL lamp. Thanks all.
try oldchevytrucks.com, bowtiebits.com and chevysofthe40s.com
found some at oreilly auto. I am set. Thanks.
