| | | Forums66 Topics128,113 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I am running a 6 volt system but I added turn signals. Can anyone point me to a 6 volt two filament lamp that would be suitable for parking and turn. Right now I am playing with two lamps but I would prefer a single lamp. I will replace the stock lamp socket with a two contact one if they are available. Plenty of 12v ones available but I have not found a 6 Volt one. Thanks. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can get universal sockets at any parts store. It doesn't matter if it is 6 or 12 volts. Use a 6 volt flasher & 6 volt bulbs. Any added wire use heavier gauge then 12 volt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | You have a source for 6 volt two filament lamp? | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I did that on my '46. I didn't want to drill holes in the fenders. The NAPA store had to special order the 1154 bulbs and I had to take the whole box of 10. It works well and looks just like original. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Thanks. I think I'll have to special order too. I struck out after work around here. But I'll use the 1154 LL lamp. Thanks all. | | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | try oldchevytrucks.com, bowtiebits.com and chevysofthe40s.com | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | found some at oreilly auto. I am set. Thanks. | | |
