| | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98420 12/13/2006 11:12 PM | Joined: May 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 26 | 1950 3600 with a 235 6 volt system with 6 volt Optima battery Here's the situation: I get up in the morning and start my truck. Drive 10 miles to work. Park, go in to work, and work 8 hours. Go back to my truck, start it up and drive home. Park, go into house, etc... Next day same thing. If that is all that I do I have no problems. Here's where the problem occurs: If I stop on the way to work or on the way home and turn off the engine, it acts like the battery is almost dead when I try to restart it (it turns over very very slowly). If I let it sit for an extended amount of time (hour or two), it will restart with no problem again. Why would it start just fine after a long period of sitting, but after a 5 minutes it acts like the battery is dead?
Any help is greatly appreciated.
'50 Chevy 3600
#98421 12/13/2006 11:32 PM | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Sounds Like the starter is building high resistance, find someone who can do a starter draw test both Cold and Hot.
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
#98422 12/13/2006 11:47 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | '50jrod3600,
bill1949 speaks the truth. It isn't the battery, it's more than likely the starter or cables and connections.
I think a typical starter current draw (6 volt) is around 250 amps. Anything way more than this and it tells you either the starter has a high internal resistance, or a little less likely, there is something in the mechanics making it REAL tough to turn the engine over.
Were any cables replaced recently with the new battery. The six volt systems requires cables the size of a old growth Redwood tree. The large cables need clean connections too.
My bet is on the starter. They are pretty easy to pop off and peek inside. Brushes and bushings are plentiful and you will feel like Mr. Goodwrench after you fix it up and it starts on the first crank.
There CAN be mechanical problems that cause this, but most of the time it is the starter/cable situation.
More folks will be along with more good info!
Stuart | | |
#98423 12/14/2006 12:18 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think Stuart pretty well covered it. If your ground cable goes to the frame make shure the ground strap from the frame to engine is heavy & connections are good. The engine tightens up when warm & the starter has more resistance. You might try setting the timing back a little. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#98424 12/14/2006 12:51 AM | Joined: May 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 26 | The starter is new (rebuilt from Carquest). When I put the new battery in, I didn't replace the cables, I think they might be the originals. I'll take a look at them and the groud strap for bad connections.
'50 Chevy 3600
#98425 12/14/2006 1:16 AM | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | read up:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002220#000001
My first thought was timing being off as well but after some reading it seems this is a pretty weird issue others have had.
1946 Chevy Pickip
#98426 12/14/2006 4:34 AM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | When the original starter on my Chev van quit.I replaced it with a rebuilt.It acted just like yours.I got a replacement and the trouble was gone | | |
#98427 12/14/2006 3:14 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Could your timin be a bit off ? hot motors will be tough to turn over if the timin is out , cold they fire right up. Have been there before. Just a suggestion | | |
#98428 12/14/2006 6:55 PM | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | I'll bet the guys who are suggesting cables are 'on to it'. Could be other things, but my 46 was pretty much the same. The cables were 12 volt and they are not good on a 6 volt system. Changed to those like "old growth Redwood trees" and never had another problem. Cheers, George | | |
