2 members (Gdads51, msmall),
62
Mod | | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | There is no seal on the bottom of the steering box on these trucks is there? I can't see one shown in the diagram. I know mine always seemed to drip a little oil from the bottom.
John | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Mine for sure does not have a seal. How heavy is your oil? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If you're talking about a leak around the adjustment screw, a dab of Permatex #2 on the threads when you rebuild it well seal it up. Won't hurt to put a dab on the sector adjustment also.
DG
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I was using 85w-140 in the box. Maybe "knuckle pudding" might be better in it. Doubt I'll rebuild it anytimne soon it doesn't seem to be worn or excess play in it.
Thanks John | | |
