8 members (Joe H, Joe Lowe III, Oswald, frogfarmer, Cosmo, DaveV, Shade Baby, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98393 12/12/2006 4:47 AM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | does anybody know where I can find parts for the unity spotlight that came off my truck? It is the type with the white handle and GE bulb. | | |
#98394 12/12/2006 5:39 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | justin squire, I poked around and found these guys. Welcome to the Stovebolt. http://www.unityusa.com/ Stuart | | |
#98395 12/12/2006 6:11 AM | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | What kind of parts do You need??? Need to know more than a white handle, and GE bulb...I have dual 5 inch spotlites on My truck made by Unity..If I don't have the part (which I am limited to only a few extra's)but I have a Friend that bought 2 Chevrolet dealers NOS stock out, may have them..BB | | |
#98396 12/12/2006 4:07 PM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | I don't have any numbers off of it, but it has the unity namecrest on the top and it has the remains of a white handle. I probably shouldn't even be looking for parts, but rather a good used one because mine is rusty and missing everything but the basic light housing and rod. The switch doesn't move either. I probably need a good used one because I found new ones from www.kanter.com/p67-lts.html for a little more than $200. I need the left hand door post mount spotlight. Thanks | | |
#98397 12/12/2006 4:59 PM | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Justin, door post ??? Are You sure You don't mean left windshield piller ??? I am sure My Friend has a Unity spotlight...might even be new ! BB | | |
#98398 12/12/2006 5:45 PM | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Got parts for my unity spotlight from napa,the guys took the time to find new pinion gear for me. my fault they broke as i used the wrong grease in it and very cold weather dont mix.Now i used electric grease on them and much better. | | |
#98399 12/12/2006 6:08 PM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | Yeah, I mean the windshield pillar. I just went out to my garage and took what is left of mine apart. Does anybody know how the movement works? I know when you twist the handle, the gears make the shaft rotate, but can't you already do that by just rotating the shaft? Also, can you change the direction the light is pointing with the controls on the inside? All I see is one gear on the spotlight end of the assembly and I don't see how anything from inside the cab turns that gear. I turned the actual light by hand and the gear turned, but nothing else was affected. Do you have to rotate it by hand to get it in the right direction, then use the handle after that? Am I missing a gear on the spotlight end? I probably need a good used one because the rivets on mine where the light housing attaches to the assembly are rusted and I can't remove the nut that is holding the light housing on either. I also measured mine and it appears to be made for a 5 inch lens. | | |
#98400 12/16/2006 5:23 AM | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Justin, My Friend Cal who has the spotlight is out of town and won't be back until Monday or Tuesday...BB | | |
#98401 12/20/2006 8:01 PM | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | I have a couple of Unitys you can have if you are ever through Belen,NM.These are newer models but most of the parts interchange.Where is Hagerman?
Gangster whites and straight pipes.....
#98402 12/21/2006 1:59 AM | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | hey I really appreciate it, but as of now, I havve just purchased one. Hagerman is between Roswell and Artesia about halfway. | | |
