0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#983668 11/05/2013 1:19 AM
I have a 36 1.5 ton chevy truck. Oil pressure dropped suddenly to zero. I checked with another gauge, same result. The oil pump screen is clean. Cannot find a rebuild kit for pump or a replacement pump. Any suggestions ? Could it not be the pump ? Help !
Jditt #983683 11/05/2013 1:46 AM
' Offline
Collectors Auto Supply has access to
a 1936 Chevy Oil Pump GM # 604510
Part# Type Price Description CT Vehicle YE AR
604510 NOS $95 OIL PUMP STAMPED 604158 ON COVER
phone:800-414-4462
or try
Private antique auto parts seller in Virginia
Bruce Bugay: [email protected]
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
'54 3600 #983690 11/05/2013 1:57 AM
I really appreciate the info. I was coming up with nothing. Will let you know how I make out
Jditt #983736 11/05/2013 4:57 AM
The Filling station has 1936 pumps listed. LINK
My Blog
Jditt #983765 11/05/2013 12:49 PM
something broke, it might be the distributor as well, either the little tab broke off, or the gear is spinning on the shaft. A pump usually won't just stop pumping due to wear. It would be more gradual over a period of possibly a couple of years.
Jditt #983776 11/05/2013 2:19 PM
' Offline
Egge Machine Co. can rebuild
your oil pump.
Egge's link:
http://www.egge.com/Oil-Pump-Remanufacturing
George
1954 3600
Now cruising in
The Passing Lane
Jditt #983793 11/05/2013 3:39 PM
H Online: Content
Make sure the pump is turning. Pressure going to zero suddenly doesn't make sense. Have you dismantled the pump to see if the gears are intact? Also check the distributor for damage to the drive tang.
Jditt #983949 11/06/2013 3:25 AM
Thank you all ! I will check this week end. I thought it was wierd the pressure dropped all at once. Thanks again !!
Jditt #984205 11/07/2013 1:18 AM
I'm with others here, your pump is not the issue, but it's easy to check.
The 1936 oil pump has a screwdriver slot at the top of the shaft that the distributer drops into. Pull the distributer out, but before you do that mark the position of the rotor so you know where it needs to be when you replace it (don't turn the engine over with the distributer out). Put a long straight bladed screwdriver shaft on a drill and run it CW and see if you can make oil pressure.
Inspect the distributer shaft while it's out.
If all looks good there and the drill makes pressure, remove and disasemble the oil distribuition valve located on the drivers side of the block, it could be blocked with a piece of trash.
Let us know what you find...Good luck!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
