5 members (frogfarmer, baldeagle, Otto Skorzeny, tclederman, Rusty Heaps), 62 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#983798 11/05/2013 4:19 PM
What 3 speed transmission was used behind the 64 Chevy 230? And is there a floor shift conversion available?
Dennis
oldbluetruck #983813 11/05/2013 5:12 PM
Back in that era Fenton shifters were the common swap backed up by Hurst. Sorry, don't know the numerical designation for the tranny.
oldbluetruck #983828 11/05/2013 6:39 PM
It was common to see them in 1/2 ton pickups.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
oldbluetruck #983893 11/05/2013 11:43 PM
Do you know if this has a brand (ie Muncie or saginaw)?
Or is it a Chevy 3 speed?
Are there identification numbers somewhere on it?
Thank you
Dennis
oldbluetruck #983964 11/06/2013 4:18 AM
Your truck is almost 50 years old. It was also made about the time GM started to switch over to the all synchro 3spd trans Muncie and Saginaw. Here is a quote from this thread at 67-72trucks, :"
IF it's got a 4-bolt side cover, it's a MUNCIE 3-speed, used from 55-65, in basically the same configuration n(X-frame cars used a shorter version, trucks bolted to the bellhousing differently). I don't know why, but a lot of guys refer to them as "Saginaws". The Saginaw however, came out in 66, and has a 7-bolt, flat bottom, side cover (both 3 and 4 speeds). There was a MUNCIE 3-speed used in 69-70 in some GM cars, but they are rare. A Borg-Warner 3-speed was also used in the "mid" 60's in some GM cars; it has a curved bottom side cover, they are rare also. Any manual trans with overdrive will have a solenoid, govenor, and separate shift lever on the extension housing as aprt of the O.D. Now, there was even a FORD Dearborn, top loader-style, 3-speed used in Pontiacs mid to late 60's (I guess to balance things out out the G.M. Hydra-matics used in some Lincolns in the early 50's). Pics are always helpful. Butch/56sedandelivery." Here is the thread at chevytalk;
http://www.chevytalk.org/fusionbb/showtopic.php?tid/279792/
scroll through it there are pictures and casting numbers.
Larry
I don't own a vehicle that isn't old enough to drink.
oldbluetruck #984089 11/06/2013 5:29 PM
Thank you very much
Dennis
