| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Anyone know what the 3 speed transmission was behind thes 1964 230 engines and if a floor shifter converter is available?
Thank you
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy oldbluetruck, I think the standard transmission was the SM318, there was also available a heavy duty transmission that was fully synchronized, its designation escapes me at the moment. There were floor shift conversion kits sold in the old days, the Hurst Mystery shifter was one, I don't know if you can still buy them new or not. So to begin your search, you have to know if your transmission is the fully synchronized one, or if it is only synchronized in second and third gear. If you have the fully synchronized transmission, just post that here and I will find the designation for that transmission, hope that helps. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you. I will look for any numbers on the transmission and post my findings.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Looks like I have a Borg Warner T89B-148 or 14B 3 speed.
Where can I go to get information?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | to a Ford forum  50's or 60's Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | A Ford transmission will match up to a Chevy housing?
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I have that same transmission. I pulled it out of a '64 half ton. I believe it was the heavy duty option. Photo | | |
