4 members (baldeagle, NorCal52Suburban, DaveV, Opelika Tom), 107 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
#98365 12/09/2006 7:01 AM
for 47-54, L&R have 3cp bulbs (2) sockets
with 2 single filiment bulbs...The bulbs are no
brighter then the dash lights...
My question, I would like to convert over to
a kit that allows Yout to use a double contact,
doule element bulb that gives off 21cp...I want
people to see My brake lights.....any other ways here.. Thanks. BB
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
I had the exact same problem. I got a kit from LMC for converting the front parking lights to dual element lamps. Had to bend the bracket just a little so the lamps would clear the lenses, but they worked fine in the taillights. My brake lights will just about blind you!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
V
V Offline
Pictures?
Thanks folks for the replies...I have the conversion kit on order....BB
I've got 1157-type trailer lights on the back of mine. The bed isn't stock, and it will be coming off eventually.
They work pretty well.
I sympathize with ya Bill, that was the third thing I noticed about the junk I bought for a right hand accessory tail light on my ’50, 3604. The first was that the chrome bezel didn’t fit worth a darn. Large gaps all around, like 1/8” in places, at the top where the rain could get in I could literally look inside and see the socket bracket, and yes the gasket was in behind the lens. The shape was a very poor copy of the original, nose was all wrong, and it was much thinner than the original and the plastic lens didn’t fit in the opening correctly, it rocked on high spots in some places and was too tight in other places. The glass lens that I was originally going to use really didn’t fit at all without bending the bezel.
Inside it had two, that were marked, 6v 8w bulbs, I suppose they were a compromise between the #63 (3w) and #1129 (21w) bulbs that should be in there. I tried (what I know as) a #1129 stop light bulb in the upper socket, no room for it, too big, the lens/bezel wouldn’t go on to the housing. I don’t for the life of me, know who started this new system for numbering auto bulbs, all these years we had a standard for the industry, 1154, 1129, 87, 63, 55, 51, etc.
Then ya get to the mounting! I have brackets from two vendors and both are incorrect. When mounted up so the wires clear the holes, it’s upside down and the flared out hole in the back of the housing still hits the edge of the clearance; turn it right side up and the flared hole misses by a third of a hole diameter. You can see what I mean in the Webshot below. Using the mounting holes in the bracket, the light was skewed to one side and I had to slot the mounting holes to make it square with the vertical line.
So Virginia, ya want pictures, do ya?! Take a look at this crap I recently bought from one of the vendors.
http://rides.webshots.com/photo/2876706220098611668iJecQN
Bill if you’re buying the “taillamp socket bracket”, forget it, it’s just a 1/32” thick strip of 1 1/8” wide tin by 3 5/8” long with four bends in it (bend it in the vise jaws) and two holes that measure .670” in dia. I also ordered two contact sockets so I could add turn signals but they won’t fit in the holes that are in the bracket and those were the only sockets the vendor listed.
Real bummer, the more of this reproduction junk I get the more I appreciate how we used to do things here in the, good old US of A!!!
I have yet to find any thing that I have replaced that was made as good as the original and I’m several thousand bucks into new parts. Sure glad I don’t have to replace any body parts! I can imagine what kind of a nightmare that could turn out to be.
Man, I think I’m gonna go try to scrounge around the garage and find something positive out there this afternoon!!!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
V
V Offline
I see... Pictures help a lot. I have the same tail lights but I have not gotten to those parts for install yet...
brendan m
do you have a 6v system? if so what bulbs did you use to work with it?
thanks
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod
1937 1 1/2 ton Is in the driveway
6v, dual filament? 1154?
so 1154 is a 6v buld that replaces 1157?
Denny,
As odd as it sounds, the originals are upside down on an AD. I have two original right hand lights,(one is NOS in the box) and they are upside down compared to the left.
Myself and a couple of others determined that GM probably did not re-tool the right light when the AD's came out. The 40-46 used a left taillight bracket that held the license above the lamp, so the right lamp would be oriented the same on those years. When the AD's came out, they flipped the left light, but apparently didn't do the same with the right.
Also, a plastic Guide lens is the correct lens for your year, but the clear license lens is glass.
Bob
Ex Hall Monitor
Ex Hall Monitor
Quote
Yes.
I converted my housings to accept the 1154 by adapting two universal 1157/1154 sockets to fit. Sorry I didn't take pics. AFTER I did the conversion I found out about this beauty. <click>
Tiny what beauty are you talking about from this web site??? Thanks.. Peter
Ex Hall Monitor
Ex Hall Monitor
Part # C7002X. It's what's pictured at the top of the page when it loads. It's listed about half way down the page.
