Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, carbking, 2-Ton), 28 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
I have a 1942 Chevy truck with a 235 engine in it, on may way to store it for the winter a loud rumble and vibration started to happen. I put in the clutch and shut it down right away. Check the driveshaft and u-joints all was ok. Put in the clutch and restarted the engine and the rumbling and vibration came back. I pulled the plugs and found all pistons moving up and down normal. Went under and pulled the flywheel cover and found if I turn the engine over by hand with the flywheel it moves about 1/2" before the harmonic balancer starts to move. Any ideas of what could be wrong???????? Would like to talk to someone over the phone if possible but will take any suggestions you may have. Thanks!!!!!!!!Send me your number 1-262-392-2989 or [email protected] Marv.
Check your IM inbox.
Your phone number does not go though.
X
X Offline
From what you've described, it sounds like possibly a broken crankshaft to me.
Daryl
Sounds like a broken crank....
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
Q
Q Offline
Move flywheel rapidly back and forth within the half inch it takes the balancer.what you want to listen for is the clunk and to determine location of it, yes you may have a broken crank, but you may also have a loose flywheel.if it is possible to look up between oil pan and flywheel you may be able to see the end of crank when you move flywheel back and forth and see if moves at all.if not drop oil pan.then you will see what is going on for sure.
I was going to say, why not just drop the pan? I see that's already been suggested..
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Will see how things go this week I may be able to get another look at it and decide for sure what to do. Thanks to all so far trying to help!!!!!!! Will keep you posted.
Marv.
Riding in the Passing Lane
I think the balancer is loose & wallered out on the crank.
1972 Chevy c10 Cheyenne Super
Removed the oil pan and found the crank broken, now what??????????? Do I find a crank,find a later model engine or rebuild the one I have and see if any one has up dated a 1942 235 engine to a high pressure system and how it could be done. If I can rebuild the old engine to a high pressure and the cost not to much I would like to go that way. Thanks to all for trying to help!!!!!!!
Marv.
I don't know how much it would cost to machine the thrust journals in the block, but I do know crower cams (the crankshaft division) drilled my 216 crank for full pressure oiling for $180, the shipping however was just almost as much. So if you use a splash oiler crank, you won't have to get new rods, or do the machine work on the thrust journals. It is all up to you, there are several ways to go about this. You can make a full flow oil filter, full pressure oiling, or both. Once you decide how you want to proceed, then we can give you proper direction. As there are a few things that will hang you up with each of the paths you may follow.
Why are there two different threads on this?
Roy, cause someone has not alerted the Moderator to bring them together.
One was move from another forum.
Marv.
