8 members (FAST55, cmayna, Cletus1950, Phak1, Peggy M, Flatblu4748, Charles in CA, Gray_Ghost), 65 guests, and 3 robots.
Topics128,128
Posts1,056,686
Members48,452
8
8 Offline
My parking brake rod has a repair weld, so I am wondering if it is shorter then stock. My brake rod is 69 3/4 inches, from the end of the clevis where it connects to the paw at the hand brake, to the threaded end of the rod. There is also no tab or extension for a spring to connect to the rod. Did the 4400 have such a spring?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
My 45 1.5 ton had the rod cut off near the E-brake handle. Since I live in K.C. I zipped over to Jim Carters and we found a replacement in the "great basement" of used parts. I'm sure if you call them he can find a rod if its in need of replacement.
8
8 Offline
Thanks Lend-Lease, after my original post it dawned on me that my cables might be stretched. So I measured them and they are both longer then what the stock 58 1/4. So I am awaiting delivery of some NOS cables and hopefully that will do the trick.
Thats pretty convent for you having JC close by!
Curt Warren
Salt Lake City
