| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 13 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 13 | did they ever combine a 283, 327, or 350 with a 3 speed on the column?
1960 Apache 10 LWB Custom Cab Stainless Trim Package
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 |
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Mine has a 350 now with a 3 speed on the column, It came out new with a 283 3 speed on the column. | | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | They even had 307's with 3 on the tree in some 68's.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | 3 speed was the standard issue for all 1/2 ton pickups. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Since you are in the '60-'66 forum, I'll assume you are inquiring about the engine/3-speed combinations available in these years. If so:
235 six/3-speed 230 six/3-speed 250 six/3-speed 292 six/3-speed 283 V8/3-speed 327 V8/3-speed
available transmissions were:
3-speed manual 4-speed manual 2-speed Powerglide 3-speed TurboHydraMatic
These combinations cover the '60-'66 Chevy light-duty trucks. This information does not take into consideration the GM cars of the era or Chevy light-duty trucks, older than 1960 or newer than 1966.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Not all 3 speeds are the same. The SM318 was used up to the mid 60s depending whether it was a car or truck. There is also a long and short tail shaft versions of the SM318. The weak spot in the 318 is the sliding ring gear and won't take abuse. The all synchro 3 speed that replaced the 318 is a stronger trans.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | They even had 307's with 3 on the tree in some 68's. I've got a '72 307 with "3 on the tree". It also has Manual Disc Brakes. Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | I'm with C10-C90 Bill. My 71 C10 came Canadian 350/4bbl standard brakes, standard steering and three on the tree. A PO screwed up the TH350 install so badly that I have to redo it. I have upgraded the steering to power, brakes to power, wiring and interior. For Pictures; http://s1109.photobucket.com/user/Roadmarks/library/1971%20C-10?sort=6&page=1 Best wishes, Les | | |
