5 members (David Bush, NJC, Rusted Nut, GRNHydra, Hush), 52 guests, and 2 robots.
Topics128,060
Posts1,055,838
Members48,427
#983269 11/02/2013 9:24 PM
I have been reading how to adjust my carb and my timing using a pressure gauge. So, I thought I would give it a try today. I hooked my brand-new gauge to my windshield wiper tap on the intake manifold. This is on a stock, rebuilt 216. I expected to see somewhere between 15-20". To my surprise the gauge almost pegged at 30"!!!! Is this possible? Bad gauge? I looked and looked and looked to make sure that I was reading it right. And, yep, I am reading it correctly. It goes back to zero when I remove vacuum, and back to a steady 30" when I reconnect. What am I doing wrong?
daveboy
'52 Chevy 1/2 ton running original gear
Is the idle rpm high? If its a china made item who knows for sure.
The vacuum can not be higher then barometric pressure of that day. 18 - 20 for well tuned engine, 30 is a bad gauge.
Joe
