5 members (Wrenchman, 52Carl, Waveski, Bill Hanlon, fonz8261), 63 guests, and 3 robots.
Topics128,261
Posts1,058,329
Members48,485
#982461 10/30/2013 5:18 AM
Hi All,
I am putting a 235 in my 1952 3100, and would like to get higher ratios for highway.
So I may have a chance to get the rear end from a 1954. I read that they are 3.90 gear ratio, while the 47-53 are 4.11. Is this the case? Would the difference be perceptible and worthwhile?
52 3100 project
54 3100 / 3112 ice cream truck, next project
Yes - 1954 3100's had a 3.90 rear end.
Someone check my math ...
A 3.90 rear end will push your truck about 5% faster than a 4.11 at the same engine RPM.
@ 1:1 Top gear:
1 RPM at engine with a 4.11 = 1 / 4.11 RPM at wheels
1 RPM at engine with a 3.90 = 1 / 3.90 RPM at wheels
Rear wheels spin 1.0538 times faster at same engine RPM with 3.90 than with 4.11.
(4.11 / 3.90 = 1.0538)
At same engine RPM -
> 50mph with 4.11 = 52.7mph with 3.90 = (50mph X 1.0538)
> 60mph with 4.11 = 63.2mph with 3.90 = (60mph X 1.0538)
Replacing the rear end is your call.
A previous owner replaced the 3.90 in my '54 3104 with a 1950 4.11. I don't feel that I would gain enough to justify changing back to a 3.90 other knowing that I have the correct rear end. My ol' truck is no speed demon, so it's a moot point.
- Lonnie
- Lonnie
My '54 3104
thanks for the detailed answer. At 5% it sounds like a marginal improvement.
On the other hand the 54 rear end is a lot cheaper (i.e. free) than the Patricks gear set, and it should be a much simpler bolt-in, right? Could it be worth a try?
52 3100 project
Well, I now have that 3.90 rear end sitting in the garage - torque tube axles drums and all. Which would be the better way to go:
a) swap the 3.90 gears into the current (4.11) housing. How complicated is this?
b) swap the entire setup -- torque tube through axles to drum?
52 3100 project
I would just put the torque tube with the 3.9 gear set, as an assembly, in your axle housing. That is unless there is something wrong with the 52 axle housing.
My Blog
Thanks. So, it would work to just disconnect and swap whatever unbolts from the front pumpkin cover forward?
No can of worms pressing bushings or rivets to swap gears? That sounds a lot simpler than descriptions of the Patricks conversion.
52 3100 project
If you change the torque tube as an assembly you will not need to touch the gears or adjust anything, as long as it is in good condition.
My Blog
