0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#983325 11/03/2013 2:36 AM
getting ready to rewire truck , on wiring diagram a note .... " ALL WIRES MARKED * ARE USED FOR RD ONLY " I have no idea what that means .. help please....
also I don't see any fuses or fuse block ....please explain .... thank you....
" STUCK IN THE '50'S "
What make, year, and size truck?
Where did you buy the wiring set, and what is the part number?
Depending on the year, a fuse block might not come with a replacement wiring harness.
1955 1st series , when I bought the truck it had no wires, I have only bought a fuse block 12 circuits off e-bay today. Not planning to buy a harness just wires and switches light etc.. The wiring diagram I pulled up off this forum ....
I did locate a fuse block and cover for tail and stop light .... I'm thinking the light switch had a circuit breaker on it....for the lights ....
Right hand drive.
cool, thank you ....
