| | | Forums66 Topics128,161 Posts1,056,956 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | What do I need to look for in a 6 Volt COIL for my 1929 ?? This is for a stock 6 Volt Electrical System on my 1929 Chevrolet. Starter: Delco-Remy 714-L Distributor: Delco-Remy 633-G Generator: Delco-Remy 943-J
From what I have found so far in my research about Stock Delco-Remy 528-C Coil: Voltage: 6 Volts Primary Reistance: 0.5 - 0.9 Ohms ...(Connector to Connector) Secondary Resistance: 5k - 10k Ohms ...(Connector to Tower)
Read something about a Ballast Resistor ?? Do NOT think I need one for my Application
Found These Available, Stated as 6 Voil Coils, but no Coil Specs: Allis-Chalmers.............0236481..$25.....Tractor Supply Company BWD........................E5.......$25.....Advance & O'Reilly BWD........................E5P......$20.....Advance BWD........................E70P.....$28.....Advance Delco......................U520.....$30.....RockAuto Standard Motor Product.....UC14.....$20.....RockAuto Duralast...................c809.....$17.....Autozone Echlin.....................IC7......$28.....NAPA Echlin.....................IC7SB....$13.....NAPA
Found Specs on this One: Airtex Wells...............5C1063..$20.....RockAuto .....Voltage: 6 Volts .....Primary Reistance: 1.0 - 1.4 Ohms .....Secondary Resistance: 5.5k - 9.5k Ohms
Anyone Using any of these or have recommendations ?? Do not want to blindly test one out and do damage to my 1929. 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I see you posted over on the AACA site also. Your answer may come from them as they are more in tune with the neat really old cars. I see no reason for a ballast resistor. The coils with a higher primary resistance will lower the current drain from your system so I see no harm in that. The spark voltage will also be reduced somewhat. If starting is not a problem then I would just go with the one that most closely matches your old one.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I got a coil from TSC. The package said made in USA, but the coil said made in China on it. The coil seemed kind of cheap made, the case was a flexible plastic. Didn't seem to work that well either. Bought a coil from NAPA worked much better.
John | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | I would recommend an Echlin IC8 6 volt coil. I used that on a 1922 American LaFrance and it is what I use on my 1936 GMC. Been a while since I bought one but I can't imagine that it is more than $30. | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Have had a few guys tell me to stay away from the ones at TSC, really cheap... Quality that is, short life span.
dunfire I was able to find that NAPA Carries the Echlin IC7 but no listing for a IC8 ??
Also Talked with my Local O'Reilly s they have the BWD E5 6 Volt Coil in stock all day for about $22, think I will swing by and take a look n see. May stop over at NAPA as well to see what they can do for me. 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | The IC8 may have been superseded by the IC7, I will check the NAPA store close to me, it has been about 8 years since I last bought one. | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Ok, let me know what you find out ...
Talked to the locals here at NAPA they have the IC7 instock for $27 and can get the IC7SB for $14
IC7 has a 3 year warranty and is Echlin Brand IC7SB has 1 year warranty and is Mileage Plus Value Brand 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | |
