| | | Forums66 Topics128,263 Posts1,058,134 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi. I will begin work on a 1933 REO speedwagon. The truck has a 230 from a 1962 Nova. Is this the same 230 you folks have in your 1/2 tons? How do I ID the engine, bell housing, and transmission? Are numbers stamped on them and where?
Thanks Dennis
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2011 Posts: 2,952 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,952 | My 1965 230ci has a stamped number just to the rear of the distributor hole. I'll let others say what they know about the tranny and bell ID.
| | | | | Joined: Feb 2004 Posts: 29,923 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,923 | If it's from a 62 model, it's probably a 194, not a 230. All of the second-generation 6 cylinder engines have the same bellhousing bolt pattern as the V8's. Any manual transmission from the mid-1950's on could be bolted onto the bellhousings that fit those engines, 3, 4, or 5 speeds. That would include the Muncie 3 and 4 speeds, the Saginaw 3 and 4 speeds, and various Borg-Warner 3,4, and 5 speeds with the Chevrolet bolt pattern. Even an SM-420 could bolt up and work. Jerry
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you.
I believe the engines stamped number is P1024PV
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Found out the ending PV shows it to be a 64-66 230 with a 3 speed manual transmission. I used Nova Resourses website
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The six cylinder in the trucks were a 230 CID in '65 & a 250 CID in '66.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it did come out of a Nova It has or did have the oil pan sump in the front part of the pan & the dipstick in front also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
