3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#98196 11/21/2006 7:44 PM
i'm wondering if anybody supplies the old style round wire connectors? i'm wiring up my cooler motor and don't want to use the blade style because i would have to cut the round ones off the wires running from the switch.
any body know?
#98197 11/21/2006 7:52 PM
p.j.,
These are called bullet connectors and are readily available...is this what you are describing?
http://www.audioadaptors.com/parts/connectors/bullet/RFBC-RMBC.jpg
Stuart
#98198 11/21/2006 8:18 PM
yep!
don't suppose they come in the solid brass like the originals?? i know, i know...picky, picky, picky.
thanks atomarc! i'll go check them out.
#98199 11/21/2006 9:13 PM
p.j.,
Actually I think they do come in solid brass. I did a Google search using 'bullet connector', then clicked on 'images'. I think I saw a site with solid, uninsulated brass connectors...good luck!
Stuart
#98200 11/21/2006 9:14 PM
check your local hardware store... they have lots of goodies.. and usually, they are cheaper than the car parts store..
Another quality post.
Real Trucks Rattle
#98201 11/21/2006 10:35 PM
found em! thanks for your help guys!
#98202 12/05/2006 1:21 AM
V
V Offline
www.riwire.com
they have the original bullet connectors along with the original "wade" connectors used on AD era trucks.
Gangster whites and straight pipes.....
