0 members (),
80
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Mine have been bondo'd over too. I plan on re-drilling the holes (from the underside) and using 3/16 carriage bolts. The heads look like rivet heads.
Joe
BTW looks like Transport Blue under that Bondo
1955 First Series 3100
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Hah. May look blue, but is actually a lighter green than the surface paint.
Drew
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Rivets are exposed from factory. I plan on puddle welding holes closed in bracket. Then I will puddle weld bracket to fender through holes in fender. Grind smooth, a little plastic filler and done. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That seems a good way to attach and clean up the bracket.
Drew
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | I'm kind of partial to the rivets showing, even if they aren't exactly practical.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Original was with the rivet heads showing. Disadvantage to permanently attaching the brace to the fender is when you are handling the fender during body work, such as stripping, straightening, sanding, painting the brace just gets in the way. Replacement 'rivet head stove bolts are available from here: http://www.parts123.com/0000014a/GM...evrolet_rivet_head_bolt_set-gm-1121k.htmDenny G.
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks Denny! I had looked at their catalog, but missed them. I think I'll go with that style. Just welding in a small patch and cleaning the fender has my attention now. But thanks, again.
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
Were those rivet heads painted or left natural?
Thanks, | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | We've hashed this out in years past, that is the assembly sequence. Since the beds were painted with the fenders in place at the factory Tim, I'm 'bout 99.9% sure they would have been painted. Makes no sense to assemble the bed/fender assembly with out the center brace being riveted and bolted in place. At least I've never seen one that didn't have them painted unless it was an attempted restoration of some sort. If your restoring one and you choose to wait till the fender is painted before putting the brace in, then it's a simple matter to take a dab of touch-up paint to the rivet head.
I realize that there are some guys that choose to level off all of the spot welds, seams, low spots, waves and such in an effort to make their Stovebolt look like a 2014 Silverado and that's just fine with me. There are those that insist on installing welting between the bed and fender also, even though millions of Stovebolts were delivered without it and seemed to survive for some odd reason, for well over a half century. But.... if you're goal is a "restoration" then I'd leave the rear fender center brace rivet heads showing and just paint them.
Denny Graham Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Denny
I paint them, too. I remember the former discussion on this. Seems a good idea to also have this info in this thread, too.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | IF you decide to put a coat of filler over the rivet, you should weld the rivet head to the fender first. If you don't you run the risk of movement causing the filler to really ruin your day.
Best to just leave the rivet showing, but its personal choice. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Deve, Just ordered the rivets today and plan on just painting them as per advice received. The cracking of the filler was exactly what happened among other rust issues. But at least my patch welding is done and I am well on the way to primer. Might even post a pic or two when done. It's bragging, but we all like pics here.
Drew
