11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#98179 11/20/2006 9:50 PM | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | I am trying to finish the wiring on my 50 1/2 ton and didn't do the best job under the dash to see when the original wiring harness was removed, where the new wires attach. #1 I have a Signal Stat 400 turn signal that has 4 wires coming out. Is there a diagram for this connection? #2 Where is the "stoplamp switch" located to attach the brake lights? I realize these are obvious to most, so pardon my rookiness. | | |
#98180 11/20/2006 10:32 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | GoCougs, There seem to be quite a few different turn signal units, each with its own wiring configuration. I stuck in a link to a few sites that might help you. The brake light switch should be in the lower firewall area near the brake pedal arm (engine compartment side). It's a small lever actuated switch. http://www.oldgmctrucks.com/page0262.html http://www.film.queensu.ca/CJ3B/Tech/SignalWiring.html Stuart | | |
#98181 11/20/2006 11:55 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can,t run your brake lights through the turn switch useing that switch. you will have to add extra lights on the rear or use a 7 or 8 wire switch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#98182 11/21/2006 5:12 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is a Tech Tip right here on the Stovebolt site. It doesn't include the 4 wire switch but it tells you how to figure out any switch's wiring. Wrenchbender Ret. is right about the brake lights so you won't need to look for that connection when you diagram it. | | |
