| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Is there a difference between a 55 second series and a 57 right front fender. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | minor difference because the 57 has some flats with holes where the grill mounts on top the raised lip, the 55/6 grill fits inside the hole, easy enough to patch the 57 for use on the earlier, little harder to use the earlier fender with the later grill - otherwise they're identical
Bill | | |
