1 members (Otto Skorzeny), 74 guests, and 1 robot.
Topics128,132
Posts1,056,730
Members48,454
#981667 10/26/2013 11:40 PM
Does the clutch pedal linkage only go in one way?
After rebuilding the pressure plate and clutch I could only find one way to install the linkage. However, when it was all assembled I had to adjust the linkage to it's max and still the pressure plate would not disengage. I see it separate slightly when the pedal is completely pressed, but with the engine running it is if I wasn't even pressing the clutch. I haven't gotten around to purchasing a manual yet and I'm wondering if anybody has some pics of an assembled clutch linkage or a link to a manual illustration.
Glory Bound...
Hmmm, something sounds wrong here. You sure you got the clutch disc installed the right way? If it's backwards it could be putting the pressure plate in a 'bind'.
1950 4100 - unrestored and driven weekly for almost no reason at all.
55 manual should do [2 different types possible]
are you sure you got the throwout bearing in the right way round?
The clutch disc if turned around makes contact with the flywheel. So I think that went in correctly.
As for the throw out bearing, the fork is grabbing it with the actual bearing making contact with the three diaphragm spring fingers on the pressure plate.
Glory Bound...
Did you put the same style pressure plate in that was in it? Did you compare the new to bearing to the old one to make sure they were the same length?
I installed the same pressure plate after it was rebuilt. The gentleman I bought this truck from had gone through it ten years ago and then basically parked it so I checked the bearing for smooth operation and re-used it.
What I'm thinking is the place that rebuilt the pressure plate made a mistake somewhere.
Anyway to check where the diaphragm spring fingers should be with the clutch and tranny installed?
Glory Bound...
Is your pressure plate a diaphragm type? A 2 ton truck should have a 3 finger / lever type pressure plate in it.
It is a three finger lever type pressure plate. I was just going by the terminology that is on the manual which is linked on the second reply to this post.
Glory Bound...
further along in the manual is the coil spring clutch, picture there might help
I doubt anyone who would be capable of rebuilding a pressure plate would have got it together wrong
If anyone is still following this post I just wanted to update you guys. Where I went wrong was using the same throw out bearing. I took the pressure plate to the gentleman that had rebuilt and started explaining my problem when he interrupted and asked if I had the correct throw out bearing. I told him I used the same one that came off. Just like I told Don Stocker on this post. He came back with: "That doesn't mean it's the right one, even if it WAS working before." So I headed to O'Rileys auto parts and sure enough the correct throw out bearing is longer/wider whatever, and presses deeper into the pressure plate. Thanks guys.
Glory Bound...
Thanks for the update! It's always nice to hear things worked out in the end and that it wsn't anything major...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
