Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Southerntruck, Otto Skorzeny), 130 guests, and 5 robots.
Topics128,281
Posts1,058,464
Members48,490
#981279 10/25/2013 9:26 AM
Ok. As some have read I am rebuilding a '53 in Italy. I just torqued down the crankshaft caps (100-110 ft lbs), as well as the connecting rods bolts (50 ft lbs). I failed to notice that my EU purchased torque wrench is in Newtons. So, I used 110 Newton measurement, which is (according to the chart) app. 80 ft lbs. I got it all sealed up nicely, oil pan on, and started mounting to other items on the engine (which is on an engine stand) SO MY QUESTION: should I drop the oil pan, and re-torque the bolts, or would you leave it alone? Is there a real possibility that the bolts will back off and cause damage to the engine. Thanks. Steven
1953 3100
Melbourne, FL
Veteran
Shaanxi #981280 10/25/2013 10:11 AM
better safe than sorry. I do not know it will affect oil pressure or not. I would feel sick if something happened and I remember that I did not torque it properly. I would love to hear what other people say
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Shaanxi #981281 10/25/2013 10:27 AM
Drop the pan and re-torque it!
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Shaanxi #981288 10/25/2013 12:09 PM
I think you are a little high on the rods. I haven't looked it up but I think they are 45 ft lbs tops.
1951 1 Ton Completed
If it were mine I would drop the oil pan, loosen the rod nuts and main cap bolts and re-torque them to the proper spec.
Thanks guys. I guess a proper job is just that. I'll learn to wear my reading glasses next time.
1953 3100
Melbourne, FL
Veteran
