0 members (),
137
0
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 12 New Guy | | New Guy Joined: Feb 2012 Posts: 12 | Just purchased a 69 shortbed. Previous owner had dropped in a crate 350 and a new jegs auto tranny. The speedometer works but is not accurate. 85 on the speedo is actually 70 on the pavement.
I have done searches, but have not discovered any way to fix this. Is there an adapter or converter that will put my speedometer back to proper accuracy? I don't want to change the stock instruments unless I have to.
Thank you in advance for any help you can offer.
jim in WV | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | What kind of speedo is it? If it's mechanical, there may be tranny speedo drive gear adapters that can correct the reading. If it's electronic, you should be able to adjust the dip switches. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Are the tires factory sized?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most of the late model GM auto trans. have a large driven gear for the speedo. You can jugel the gears according to number of teeth. Pull the gear out & the tooth count is usually marked on it, or count them. Get one that has about 2-3 more teeth. Check the odometer against the mile markers on the freeway. If you get the odometer correct the speed is usually right also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Check tire size first. If the speedo is reading fast he proable has smaller diameter tires on it.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: May 2013 Posts: 20 New Guy | | New Guy Joined: May 2013 Posts: 20 | "85 on the speedo is actually 70 on the pavement." That should keep you from getting any speeding tickets.8~) Cliff | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Check with these guys - PATC. They built me a ratio adapter for my 3sp OD in my 55 1st series. They also seem to have a truckload of replacement speedo gears. regards, Leon | | | | | Joined: Feb 2012 Posts: 12 New Guy | | New Guy Joined: Feb 2012 Posts: 12 | Thanks for the replies, the tires are very close to stock and the speedo drive is mechanical. I thought maybe the diff gears being different may have thrown things off. I haven't had a chance to get under the truck and check the drive gears yet, trying to get the wipers working so I can get her inspected and drive it every day.
Again, thank you for all the help.
jim in wv | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Check the drive and driven gears in the transmission. Is it a TH400, TH350, TH700R4? You can find charts that tell you based on which drive gear you have in your transmission which driven gear you need, you can purchase the gear online and install it. Easy fix. If it's that far out you might need to change both gears, but that's still not too bad. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For years we fought this but now it's so easy it's almost a non-factor. GPS-GPS-GPS. It's dead accurate no matter the tire size or gear ratio. Right now you have too many teeth on the drive gear and/or too few on the driven. Stick the GPS in the truck and see what PERCENT the indicated speed is off from the real speed on the GPS. Google "speedometer drive and driven gears" and find what drive/driven combination will reduce the driven gear by that percent. The early small gears went by tooth count and the later big gears go by count and/or gear color.
Evan
| | | | | Joined: Feb 2012 Posts: 12 New Guy | | New Guy Joined: Feb 2012 Posts: 12 | Thanks again guys, I measured the distance between mile markers vs recorded milage calculated the percentage differance and bought an adapter from the company mentioned above. If that don't fix it I will look at gps speedometers. I'm not confident in my abilities to change out drive gears in the tranny output driver.
Thanks all,
jim
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Be sure and let everybody know how it turns out.
regards, Leon | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Thanks again guys, I measured the distance between mile markers vs recorded milage calculated the percentage differance and bought an adapter from the company mentioned above. If that don't fix it I will look at gps speedometers. I'm not confident in my abilities to change out drive gears in the tranny output driver.
Thanks all,
jim Just a note, if you can't change speedometer gears I don't think you should be qualified to drive. It's extremely easy, anyone can do it. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Driven gears are easy, they screw in from the outside. Drive gears require dropping the trans and opening it up. | | |
