7 members (msmall, Otto Skorzeny, Phak1, 55shaker, TUTS 59, Wayne67vert, 1 invisible), 106 guests, and 2 robots.
Topics128,095
Posts1,056,069
Members48,433
did they ever combine a 283, 327, or 350 with a 3 speed on the column?
1960 Apache 10 LWB Custom Cab Stainless Trim Package
yes, yes and yes
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
7
7 Offline
Mine has a 350 now with a 3 speed on the column, It came out new with a 283 3 speed on the column.
Former Workshop Owner
They even had 307's with 3 on the tree in some 68's.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
3 speed was the standard issue for all 1/2 ton pickups.
Since you are in the '60-'66 forum, I'll assume you are inquiring about the engine/3-speed combinations available in these years. If so:
235 six/3-speed
230 six/3-speed
250 six/3-speed
292 six/3-speed
283 V8/3-speed
327 V8/3-speed
available transmissions were:
3-speed manual
4-speed manual
2-speed Powerglide
3-speed TurboHydraMatic
These combinations cover the '60-'66 Chevy light-duty trucks. This information does not take into consideration the GM cars of the era or Chevy light-duty trucks, older than 1960 or newer than 1966.
Not all 3 speeds are the same. The SM318 was used up to the mid 60s depending whether it was a car or truck. There is also a long and short tail shaft versions of the SM318. The weak spot in the 318 is the sliding ring gear and won't take abuse. The all synchro 3 speed that replaced the 318 is a stronger trans.
Larry
I don't own a vehicle that isn't old enough to drink.
I've got a '72 307 with "3 on the tree".
It also has Manual Disc Brakes.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
I'm with C10-C90 Bill. My 71 C10 came Canadian 350/4bbl standard brakes, standard steering and three on the tree. A PO screwed up the TH350 install so badly that I have to redo it. I have upgraded the steering to power, brakes to power, wiring and interior.
For Pictures; http://s1109.photobucket.com/user/Roadmarks/library/1971%20C-10?sort=6&page=1
Best wishes, Les
