4 members (Gray_Ghost, BillCollins, Still At It, 1 invisible), 134 guests, and 2 robots.
Topics128,078
Posts1,056,054
Members48,433
#980838 10/23/2013 11:17 PM
My truck front drums have an extension on them. Is there a spindle out there I can use to get rid of this??
What do the extensions look like?
1951 1 Ton Completed
Bolts to brake drum and extends out about 5 inches. Spindle extends out same amount.
3B Offline
Hy jetmech6868, those extensions are to allow dual style wheels to be mounted reversed on the front axle. I believe a standard single wheel hub/drum can be mounted on that spindle.
I can send you a pic. Where do I send it?
It sounds like you have the extensions as mentioned above, for a 1 Ton dually. I don't think there is such a thing as a 3/4 Ton dually from the factory so maybe this is someone's creation.
Yes these sounds like the extensions for a dually. It's hard to know what someone was thinking when talking about stuff done to a 60 year old truck.
My 46 GMC on Photobucket
The 3600 and 3800 trucks used the same spindle. Is it possible you actually have a 3800 truck? Or, like a pevious post, someone may have put the extension on from a dually truck.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Well vin says its a 3600. But I guess they are extensions. So the fun part is finding correct hubs to put on. Thanks for the help...
