4 members (RoadsScholar, Mike Roache, moparguy, 51sub), 108 guests, and 3 robots.
Topics128,070
Posts1,055,892
Members48,428
Socket Breaker
Socket Breaker
I'm installing a tachometer in my '65 c10... and I'm trying to find the wire that is the dimmer wire - the one that dims the lights on the dash, etc..
-W
This link shows it is a gray wire coming off the fuse box. If you scroll down 2/3 the page you can see a link to the 65 diagrams.
http://rmcavoy.freeshell.org/Truck_gauges.html
hook it to PANEL, 3 amp fuse on the fusebox,,Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Socket Breaker
Socket Breaker
Thanks fellas.
grin
-W
if you want the tach light to dim with the dash lights you may need to hook it to the switch. you should be able to figure the wire by care fully tracing. you know, that upside down dust in your eyes under the dash stuff.
"It ain't a truck if you can't hose out the cab."
